high idle issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2009, 01:40 PM   #1 (permalink)
View chris3152's Photo Gallery
3rd Generation high idle issue
Hi I'm new to this forum. I just bought a 93 Camry V6 XLE and it has an issue with the idle and I can't figure it out. I want bringing it to the dealership to get it diagnosed to be the last resort cause i'm low on cash. Well the problem is that when its warmed up the idle sits around 1,200 sometimes it goes higher until i hit the gas in park and it goes back to 1,200 then when I put in drive it jumps into gear because the idles so high and rpms go down to about 950 to 1,000 and then when I put it in park goes back to 1,200 or higher so I have not been driving because I dont want to mess anything up. I already cleaned the IAC and the throttle body with o2 safe cleaner and also replaced the pcv valve did not make any difference still does the same thing. any help would be great
chris3152 is offline   Reply With Quote
Old 06-23-2009, 02:26 PM   #2 (permalink)
View davemac2's Photo Gallery
Check your throttle position sensor (make sure it is not loose and is adjusted properly, and no dead spots), your air intake sensor/flap near the air filter to make sure it isn't stuck. Then check all of the vacuum hoses for any cracks. It could be a bad IAC, but on the V6, those IAC's are pretty robust. It can also be the engine temp sensor on the water jacket.
dave mc
davemac2 is offline   Reply With Quote
Old 06-23-2009, 05:07 PM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $543251
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I would check 3 things:
-Idle Air Control Valve
-Throttle position sensor
-Inlet and outlet temperature sensors for the radiator
projektvertx is offline   Reply With Quote
Old 06-23-2009, 05:15 PM   #4 (permalink)
thanks i will check them but also i forgot to add that the speedometer isnt working so im guessing the vss is bad could that be the cause of the idle issue also
Old 06-23-2009, 05:16 PM   #5 (permalink)
and how to i make sure the air intake sensor near the air filter isnt stuck
Old 06-23-2009, 05:59 PM   #6 (permalink)
Remove the air filter cover and observe its operation when reving the engine. it should be completely closed (I think) when the engine is off. Maybe someone else can pipe in with details on this one since I'm not too familiar with its specific behavior under different conditions.
You may also want to remove the 4" intake hose and observe the operation of the IAC piston valve just inside the TB. If that is sticking, you may find it struggling to seat as the throttle plate is opened and closed. Also make sure the throttle butterfly plate is fully closed when the engine is idling. Something may be sticking on that mechanism.
If you have a vacuum leak somewhere on your gaskets, you can use some carb cleaner fluid or something similar and spray around the intake plemnum gasket area and other areas. Has there been any disassembly of the intake or TB parts prior to this high idle symptom?
dave mc
Old 06-23-2009, 06:19 PM   #7 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
no, not without a really interesting short or faulty ecu.
SexieWASD is offline   Reply With Quote
Old 06-23-2009, 07:48 PM   #8 (permalink)
i dont know i just bought it
Old 06-29-2009, 12:28 PM   #9 (permalink)
hey guys im back and i still cant figure it out i took it to the toyota dealer and wound up paying $50 for them to check it out and they said the iac was bad so i didnt want to spend the $189 for themto put it in so i did it but its still got a problem it sits below 1000 rpms now but i dont know how to adjust the tps correctly scince i messed with it when i was trying to figure out the problem and also if i hit the gas to hard when im driving the rpms start going high again almost 3000 in park then i unplug the battery for 5 minutes and its fine again any help would be great cause i really dont want to take it back to the dealer again this problem is just getting annoying now
Old 06-29-2009, 12:53 PM   #10 (permalink)
There is a procedure to check and adjust the TPS. Do you have the manual?
Did u use a new gasket when you installed the new IAC?
dave mc
Old 07-01-2009, 10:51 AM   #11 (permalink)
yeah i put a new gasket on with it and i have a haynes manual for it but i don't have the tool to apply vacuum and a feeler gauge to test it properly
Old 07-02-2009, 01:02 AM   #12 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Check thoroughly yourself for a vaccuum leak, feel around because this has happened to me plenty of times
Camry, Version 2.0
JCamry94 is offline   Reply With Quote
Old 07-02-2009, 01:22 PM   #13 (permalink)
thanks i checked with some intake cleaner o2 safe and i didnt hear the idle change at all and i still dont think the tps is adjusted right still messing with it though
Old 07-02-2009, 03:37 PM   #14 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Yes check for a vacuum leak that can definately raise the idle on your car. The idle air control valve is also another good candidate for having high idle
RU2CHKN is offline   Reply With Quote
