brake flush -- brake switch issues -- ABS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2009, 01:18 AM   #1 (permalink)
View keithminn's Photo Gallery
Working on a 99 Camry -- flushed the brake system -- now the car is stuck in gear and the brake lights don't work. Nor does the power windows or the tach for that mater. Checked the stop fuse -- its good. Would the brake switch have been affected by the bleeding. None of the fuses look bad. Also is there a bleed procedure for the ABS -- is it necessary?
Thanks Keith
keithminn is offline   Reply With Quote
Old 06-24-2009, 07:12 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Well, flushing brake hydraulics shouldn't be causing those electrical issues.
I'd think windows, brake light switch (which controls shifter safety solenoid that's why you can't shift), and gauge are on different circuits.
Think carefully on what cables/harness you might have touched.
Old 06-24-2009, 07:42 PM   #3 (permalink)
Problem solved 100 amp alt fuse
As the electrical problems piled up I began looking for a major fuse -- found the 100 amp burnt -- available at Napa part number 782-1233. All problems solved including shifter and brake lights and seats tach windows etc. The car did start though without the fuse. Thanks for your help.
