wheel alignment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2009, 06:50 AM   #1 (permalink)
View jmp0126's Photo Gallery
wheel alignment?
Hi TNers,
Just a quick question...should a wheel alignment be needed after I recently replaced both front axles? I have a 95 Camry LE with 91,000 miles.
Thanks very much for evryone's opinions.
jmp0126 is offline   Reply With Quote
Old 06-24-2009, 09:13 AM   #2 (permalink)
Gameroom cash: $303255
No, you are not changing any of the adjustable suspension angles when simply replacing the axles.
Mike
Old 06-24-2009, 07:13 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
No, unless they've settled over the years. Do you see wear on inside or outside edges of both tires?
Old 06-25-2009, 12:26 AM   #4 (permalink)
View toysarefun's Photo Gallery
You'll know when you drive it. It should drive straight and drift just to the right all by itself if right on.
toysarefun is offline   Reply With Quote
Old 06-25-2009, 11:31 AM   #5 (permalink)
"It should drive straight and drift just to the right all by itself if right on."
It shouldn't drift at all on a level road.
Mike
Old 06-28-2009, 12:47 AM   #6 (permalink)
3rd Generation
Mike
It doesn't drift at all when driving in the city but at highway speed,65mph it will drift to the right. Any suggestions?
Old 06-28-2009, 01:20 AM   #7 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
various shops offer an alignment check for a very nominal fee, can't be bad to have it checked.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-28-2009, 11:08 AM   #8 (permalink)
Before going to have the alignment checked try switching the 2 front tires with each other. See if it now pulls to the opposite side. One of your front tires may have what's known as a radial pull. If the car still pulls to the right, then switch the 2 front tires back to their original positions and take the car to an alignment shop.
Mike
