Power steering flush questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2009, 02:16 PM   #1 (permalink)
View camry314's Photo Gallery
I have a gen 3 and I am wanting to flush my power steering fluid out. I read the DIY, but thats for a 4 cyl and a gen 4. My tank s totally different than that. Also in reading the DIY, do I need to run Dex III or power steering fluid? Below are some pics of my tank. Maybe someone can clarify which line is which and what I need to disconnect and plug and which one I drain from. Thanks!!
Originally Posted by Venom_5 View Post
"honey, i bought you this Recaro passenger seat to sit in my Camry - will you marry me?"
camry314 is offline   Reply With Quote
Old 06-24-2009, 02:38 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You have one rad fan driven by the p/s pump.
Two lower lines that point to engine are to supply fluid to pump then to device (rack or motor)
Higher lines, facing headlamp are return lines.
You can do same as the Gen4 flush by plugging one of the two supply lines that supply to pump, and tee the returns to the waste bucket.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-24-2009, 02:38 PM   #3 (permalink)
Darkside Cut Me!!!
Also
Generic p/s fluid or Dexron will work.
2004 RX330 Sport
2003 Cam I4 XLE
Old 06-24-2009, 04:03 PM   #4 (permalink)
Basically, I can leave the engine side supply lines to feed the pump, and cap off the forward lines and route the 2 return lines to a bucket. Will this work? I think it will flush both the fan and pump at the same time faster. Also I bought some Valvoline fluid.
Old 06-24-2009, 10:33 PM   #5 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Yep. You can leave the 'low pressure' hoses (leading to the pump) connected to the reservoir and disconnect the return and stick them into a bucket. I found it easiest to run the engine for 10 secs at a time to drain the system; turning the wheel full lock to lock didn't get much out for me. Also, i reckon the most annoying part is actually getting those hoses of the reservoir.
May i suggest changing those clamps to 'normal' hose clamps used on the radiator hoses. The reinforced ones are such a pain in the azz if they reinforcing ring slips off. Sometimes they don't clamp enough, causing a leak; that's what happened on my return line.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 06-25-2009, 08:18 AM   #6 (permalink)
Darkside Cut Me!!!
As Jim suggested, but keep in mind that you need dynamically sealing clamps (spring loaded type) and not worm gear type.
The spring tension will adjust to the thermal and pressure contraction and expansion of the hose/nipple that is made of plastic and rubber.
Worm clamps will not allow that and cut into the hose, and allow crud to get in or fluid escape.
2004 RX330 Sport
2003 Cam I4 XLE
Old 06-25-2009, 11:15 PM   #7 (permalink)
セクシーの定義
Lol, i'm actually suggesting that the OP should change to the 'worm gear' type hose clamp and ditch those dynamic ones. I guess my old dynamic clamps creeped from age and lost their tension. Although that's pretty good justification for keeping them. The one the OP has are alright, but the dynamic ones that have a reinforcing ring(another ring on top of it) are a PITA.
Camry history:
Old 06-26-2009, 01:46 AM   #8 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Probably a dumb question but what about removing the fluid from the reservoir and refilling? Then drive a few days or weeks and doing it again. Maybe 3 or 4 times, like a drain and fill on an auto transmission. Don't have to worry about hoses at all.
Dave's is offline   Reply With Quote
Old 06-26-2009, 05:12 AM   #9 (permalink)
I guess you could do that. I think that this is a faster way of doing that. Plus it might just be cheaper to to do it with removing the hoses. I bought 4 bottles of PS fluid for a total of 1.5L like the DIY states, and it was only about 10 bucks. So not too bad I guess.
Old 06-26-2009, 09:15 AM   #10 (permalink)
セクシーの定義
IMO, it's not that effective. There's only about a few hundred mL's of fluid in the reservoir and the system is about 1L. So you'll end up mixing old with new, and contantly mix and drain both(old and new).
Camry history:
Old 06-26-2009, 12:54 PM   #11 (permalink)
Dave's
I kind of thought the same thing about multiple drain and fills on a tranny. What is it- 4 quarts out of about 10-12? (I don't really remember, those numbers may be way off.) Just thought it would be the principle without risking causing a leak. (I hate plastic. )
Old 06-26-2009, 09:53 PM   #12 (permalink)
セクシーの定義
Well with the AT, it's you're only choice as there is still fluid in the torque converter. I doubt anyone will be willing to split the engine from the gearbox and remove torque converter (if possible with that small amount of working space) just to drain the TC properly. I hate plastic too xD
The only imperial i use is PSI and occasionally ft lbs xD I know my power steering system is about 1L or 4 quarts (gen 2 camry) and there's probably at most 1 quart in the reservoir
Camry history:
