Last year I had to re-charge my refrigerant. This year it has been running pretty good, but I noticed that it didn't seem ice cold when I ran the system. I decided to check the gauge on the filter/dryer, and noticed that around the outer rim small bubbles were slowly coming out.
Is replacing the filter/dryer a DIY job? If so what would I need? Would I just order a new part, blowing the charge of refrigerant, and then just recharge it, or would I need to vacuum it out? Or should I recharge using some the high mileage stuff with "Leak lock"?
A bit of background I did one year of HVAC back in 1991 at that time it was R12. I don't have any gauges, vacuum pumps or the like.
It illegal to blow the R-12 to the air. What is the temp coming out of the registers?(one near the evaporator.....)
I recommend recovering the refrigerent(oil too, (take to shop...)
You need to put the AC under a vacuum to remove all the moisture Or should I recharge using some the high mileage stuff with "Leak lock"? no!!!!!! DO NOT USE THE STOP LEAKS, IT WILL Gum up tools,ECT try dye instead...
You need a gauge too...
I would recommend using a dye.... to make sure there are no more leaks..
It would cheaper to use R-134a than R-12, and since R-12 is sold only to people with EPA cert... 609....
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mine is a 2000 camry. It is running R134a. I was saying that I had experience on R-12. By the way, in 1991 it was legal to blow that in the air.
I don't have a good thermostat here to get an accurate reading. It still feels cold and does its job, but I see bubbles in the window, and small bubbles in the oil that is around the window on the filter dryer.
Ok thanks. One other thought here. Back in 1991 when I did this, we had some sort of refrigeration epoxy. Since I can visibly see this slow leak around the window on the filter dryer, do you think I can go that route? (IF I find this epoxy)
1994 was year around were you have to recover the refrigent cording to SAE codes,
you'll need to evacuate the system PROPERLY by recovering the r-12. replace the dryer. hold a vacuum on the system for at least an hour and then recharge with the proper refrigerant and oil. if you can't find r-12 you will need to change out the compressor to handle the higher pressures that 134a runs at or the system will not cool effectively. and you'll need a decent set of guages and it is extremely unsafe to be running blind in a system with pumping pressures that can hover around 300-400psi...
if you can't do it right, just have a reputable a/c shop do it, then you can be sure it was done right...
The leak is proably an o-ring gone bad, although I'm surprized that it happened so quicky being you have a 2000 (R134a)(unless there's a defective tube/connection). I would first check/tighten the connections at the Filter/Dryer (F/D), if that stops the leak then just re-charge with kit at parts store since the system has not completely leaked down and exposed to air/humidity. For such a small leak over a short time I doubt you need to add oil. If the connection can't be tightened then you'll have to disconnect the F/D, which means you'll need to replace it and the oil it holds. Once off replace the o-rings at the tube connections then replace the F/D with a new unit, pull vacuum and recharge. A vacuum pump is about $300 and you also should get gauges so you might as well take it to a shop to do all the work. Labor should not be too bad given the ease with which this can be done. As well it is illegal to vent R134a, although I know every shade tree does it. The shop recovered 134 is not wasted and can be put back into your system so it will reduce the cost to re-charge.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
