Carpet cleaning cost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2009, 11:30 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I tried cleaning the carpet myself but the previous owner had left it dirty for way too long. (Coffee spills, melted starbursts, etc).
How much should I expect to pay for a professional carpet shampoo?
Retrospekt is offline   Reply With Quote
Old 06-27-2009, 11:33 PM   #2 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
I had a bunch of stains on my floor mats and I just used a regular carpet cleaner for that. It did a pretty good job of removing most of them but it took me about 30 min to scrub all of them. What cleaner did you use?
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 06-27-2009, 11:35 PM   #3 (permalink)
Slowly learning....
I used a very expensive carpet cleaner that came with my mom's (now dead) carpet cleaning vacuum. It abused my hands a bit but didn't clean the carpet's too well.
The problem with my carpet is that the dirt has been stuck so long, there's layers of it. I can scrub all day long (I did a 3 hour cleaning today), but all that does it spread the dirt around and there's nothing to pick it up. I can't use my vacuum because it's not powerful enough and the water will kill it.
Old 06-27-2009, 11:50 PM   #4 (permalink)
'_'
Touge Star
'_''s Avatar
I'd try and use a vacuum if you can get one, or look into the steam cleaning and whatever else that involves like you said. If that doesn't work, I'd probably just buy a new set of floormats. If people tend to spill stuff in your car, maybe try rubber/plastic floormats or something.
山道だいすきです。
Old 06-27-2009, 11:58 PM   #5 (permalink)
Slowly learning....
The floor mats are in the garbage. The residue got underneath the mats and is on the carpet itself. Getting a vacuum that can handle water pickup is probably going to be a bit more expensive than a professional shampooing.
Old 06-28-2009, 06:30 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
replacement carpet is only like $200 or so...www.summitracing.com just a thought
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 06-28-2009, 08:50 PM   #7 (permalink)
View flyeri's Photo Gallery
Take the carpet out on the driveway and use Simple Green or Purple cleaner to soak all the stains. Brush them and use a pressure washer on the entire carpet. Hang the carpet up or put something under it so air can get around it to dry. This sounds drastic but believe me it will work, even on the seats. My daughter's was awful when we got it.
I have also used the Bissell carpet cleaner with the hose attachment. Again spray (soak) the stain with cleaner and then vac out the liquid. Leave all doors open and use a fan to help dry.
The normal household carpet cleaner stuff is just not tough enough to get the junk that you described loosened up.
flyeri is offline   Reply With Quote
Old 06-28-2009, 09:48 PM   #8 (permalink)
Slowly learning....
Guys, this isn't like a floor mat carpet. This is the carpet attached to the car chassis. The idiot that owned the car before me didn't have any type of mat on top of it.
Old 06-29-2009, 11:01 AM   #9 (permalink)
View bass4lyfe's Photo Gallery
you can take it out...
bass4lyfe is offline   Reply With Quote
Old 06-29-2009, 11:52 AM   #10 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
Thumbs up
pull it out rally style hahaha where do you live i can get you one if your in new england
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 06-29-2009, 12:29 PM   #11 (permalink)
We know. It comes out anyway. If you don't feel comfortable taking it out then look at the 2md paragraph of my post. That method works well also.
Good luck. Sounds like you hate a dirty car as much as I do.
Old 06-29-2009, 01:26 PM   #12 (permalink)
Slowly learning....
I don't feel comfortable pulling out the carpet. I might go and rent one of those RugDoctor Vacs from Walmart or borrow a Bissel Vac from someone.
For now I just used some Oxi Clean and scrubbed for hours. It didn't clean it all the way, but it freshened it and my car smells nice. I found some nicely fitted rugs at walmart that match the interior color and put them over the dirty carpet.
Thanks guys.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Old 06-29-2009, 06:06 PM   #13 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Go rent a Thermax. It'll get it out. I promise.
www.thermaxaf.com
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 06-29-2009, 07:06 PM   #14 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
A Rug Doctor is a good Vac for cleaning carpets,for sure.
ASG14 and I rented one a couple of times to clean my carpet, after he removed it from the car, but...if you feel your unable to remove the carpet, you should be able to just remove the front seats, its not that hard....it would make it a lot ezer to get the carpet really clean!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 06-29-2009, 07:22 PM   #15 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Each front seat is basically held by 4 bolts. There's an electrical connector or two - seat belt/power seats if you have them.
The rear seat cushion basically pulls off.
I bought a Hoover Steam Carpet Shampoo Cleaner a couple of years back. What i found is that it works good in the house, but only so so in the car --> anytime I need to use an attachment, the performance is only so so.
These carpet cleaners work surprisingly well on stains.
The built-in brush works well.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
