My GEN3 is Dying ??? :( (Shacking) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2009, 10:06 AM   #1 (permalink)
View 94_v6_camry's Photo Gallery
3rd Generation My GEN3 is Dying ??? :( (Shacking)
Guys, need some help, lately i noticed my car is shacking even at idle, and sometime it wont start from the morning, anything i need to check before i take it the mechanic???
Derrick
94_v6_camry is offline   Reply With Quote
Old 06-28-2009, 04:50 PM   #2 (permalink)
View jermag24's Photo Gallery
What is behind on maintenance? Spark plugs, spark plug wires, fuel filter, etc... are cheap maintenance items that can disable your car if neglected.
Get a manual and make sure you're up to date on all routine maintenance items.
jermag24 is offline   Reply With Quote
Old 06-28-2009, 04:57 PM   #3 (permalink)
View 500KCamry's Photo Gallery
Derrick
Start with the "DIY" concerning cleaning the intake. It does wonders.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-30-2009, 05:48 AM   #4 (permalink)
I did try to clean the intake, but noticed my car start to shack badly and the temp go pass 80%!
What would be the likely cause...i have check there is enough coolant!
Derrick
Old 06-30-2009, 06:29 AM   #5 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Bad thermostat... water pump not workin... head gasket gone... not enough coolant...
The shaking can be a bad plug mate. Mine used to have a lil "chugging" noise when my Vienta was firing on only 5 cylinders instead of 6 hahahaha!! Sounded like a V8 weirdly enough :P
Good luck mate..
whip_cracker is offline   Reply With Quote
Old 06-30-2009, 09:24 AM   #6 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Check your EGR valve as well
RU2CHKN is offline   Reply With Quote
Old 06-30-2009, 01:35 PM   #7 (permalink)
Good luck mate..
Hmmm just check one of my plug is bad hence causing the shacking!
Still concern about the temp thro...i run the car and after it reach normal temp....smoke still coming out of the exhaust...could it be the head gasket is giving up soon?
Derrick
Old 06-30-2009, 02:15 PM   #8 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
check for vac leaks, and pull any codes......, what year is the camry?
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 06-30-2009, 11:04 PM   #9 (permalink)
Ok here is an update car is in really bad shape :-(
As i was driving to work this morning, noticed the temp gauge rich the red mark, so i stop and open the bonnet and check the coolant it look fine then i check the engine oil cap....and there is mixture of engine and coolant together (milky colour)!
So bad that i call the mechanic and got a few quotes...look like its not worst fixing as the cost of fixing wont be cheap!
Derrick
Old 06-30-2009, 11:34 PM   #10 (permalink)
View toysarefun's Photo Gallery
That sucks. With new car incentive out, cars are dirt cheap bro. Sell it for parts and use the cash to get into something that is running for you. You should be able to find a nice yota and talk them down. Check craigslist for dummies that fried the starter or broke a timing belt and get a yota cheap. Or just shop around for one that was cared for.
toysarefun is offline   Reply With Quote
