Originally Posted by Mike Gerber
There is always a risk when buying the parts yourself and bringing them somewhere to be installed. Is the Midas going to install parts you bring in? If so, will it change the amount they will charge you for labor? (Most shops make a profit on the parts they install.) If one of the parts is defective after the install it's you who will have to pay again to have the part removed and a new one installed. If you bought the parts over the internet, the supplier will most likely want the defective part back before sending you a new one. That means you will have to have someone remove the part to send and in the case of struts, your car becomes undrivable while you send the part back and wait for the new part to arrive. Is a place like Midas going to store your car for you while it is undrivable? Can you be without your car for a period of time? Just a few things to consider.
Mike
well...if you go to one of my uncle's shops then your likely to have problems with the install before the parts...even if ya brake them before they install them
. but some good things to consider, personally...i
know i can get the right part and can tell if somthign is wrong with it before install....then again...i would be the one installing them too.
as far as labor cost....you ask what the labor rate is before ANYTHING else. thats how Midas works, as well as most chains. that being said, they can lie and make somthing up about having to do more. theres really not much you can do about it if they do that to ya.
