Originally Posted by coughlj
With it all back together the car still will only crank but not fire. Pulled #1 plug and I do get spark.
There was some aluminum pieces from the pump in the timing cover area at the bottom of the crank sprocket where the Crank Position Sensor is. Could the sensor have been damaged and still have spark? No codes are being set.
Any help would be appreciated.
Thanks - Jeff
Recheck the timing. With the crank pulley notch at Zero, the hole in the camshaft pulley should line up with the notch or divet on the camshaft bearing housing. You need a small mirror to look through camshaft pulley hole.
As to the bottom timing belt cover problems, the crank position sensor is likely okay, but the thing that might break from debris down there are the small fingers on the crank timing belt sprocket. The sprocket is difficult to pull without breaking these also.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
