My drivers side seatbelt reel won't pull the belt in at all. Even if I help it with my hand, it barely goes in. I have the feeling it just crumples up under the plastic when I push it in.
How do I fix this? Is it just a loose spring or do I have to purchase something?
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
I don't think you can "fix" anything in the reel. I tried once, and couldn't get anywhere because it is sealed. But also, I think that it is more of a safety issue; there is no way to tamper with someone's seatbelt mechanism without removing it completely (and then it is quite noticeable).
I don't know if your seat belt assembly is a "pre-tensioned" one with an pyrotechnic charge in it. If so don't try to disassemble it.
Anyone? Does a 96 Camry have a pyro-technic charge in it? If not I'm going to unscrew it just so I can get a visual of how everything is fastened in so I know what to look for at the junkyard.
If it's anything like the seatbelts in my Gen 2, i'm guessing the 'roll-up' has popped off the reel. I accidentally did that to my rear passenger seatbelt reel and now it's doesn't retract. It's like a bit of plastic with a metal coil that is loaded. You're going to have to replace. I think removing is pretty simple, just remove the pillar trim and then explore.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
i just found out as my 1996 camry rear seatbelt just started doing the same thing - there isnt any pyro-technic charge. its a coiled up spring that applies the tension. i took mine apart in hopes of fixing it. i was able to re-attach the popped spring, but after i reassembled and used it a couple of times, it popped again. i will try to re-attach the spring to the plastic part that coils it and use something else to keep it in place.
if this doesnt work, its onto replacing the reel and belt.
On the parts catalog the front looks like the rear. a small spring loaded deal. But the picture is hard to tell.
Does the factory manual say anything??
My car did the same thing last year. I looked around to see if I could "fix" it to no avail. Spent, if I remember correctly, close to $200 for a new one at the stealership.
