AC Controls/Blower - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2009, 07:33 AM   #1 (permalink)
View stillmc's Photo Gallery
AC Controls/Blower
2001 Camry LE
My air flow controls have four settings. I am not getting any air flow unless I turn my control to 3 or 4. 1 and 2 don't produce any air. Any ideas? TIA.
stillmc is offline   Reply With Quote
Old 06-29-2009, 08:02 AM   #2 (permalink)
View skuttduck's Photo Gallery
Originally Posted by stillmc View Post
2001 Camry LE
It sounds like it might be your blower motor resistor. I've come across a few threads here before on this. I think one of them had pictures. However if it were me, I would go to www.toyodiy.com and get an idea of how to get at the part.
I believe this is a direct link. You can use the part number to order that directly from any of the toyotaparts websites.
http://www.toyodiy.com/parts/p_U_200...PNKA_8714.html
skuttduck is offline   Reply With Quote
Old 06-29-2009, 03:12 PM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
+1 on the resistor.
Dave's is offline   Reply With Quote
Old 06-29-2009, 04:11 PM   #4 (permalink)
Gameroom cash: $303255
+2 on the blower motor resistor.
Mike
Old 07-01-2009, 10:39 AM   #5 (permalink)
Thanks for the replies. I replaced the resistor last night and all is well!
Old 07-01-2009, 05:14 PM   #6 (permalink)
Dave's
Good to hear!
Old 02-03-2012, 04:36 PM   #7 (permalink)
View HawkeyeKid18's Photo Gallery
So can someone tell me more about this resistor? I just noticed the problem today that I have no airflow when I turn over the switches 1-3, and the blower finally kicks on when set to HI. I assume I have the same problem as above.
Also, it might not be a big deal, but I also noticed the vent flaps became louder as I turn the switch from floor, to dash, etc. Any help appreciated! Thanks.
1999 Toyota Camry LE, 2.2L I4 DOHC 16V FI Engine
Alpine CDA-105 HU
HawkeyeKid18 is offline   Reply With Quote
Old 02-03-2012, 06:27 PM   #8 (permalink)
Dave's
They used to be wire-wound resistors (one for each speed except high) but they're increasingly electronic. Usually they are pretty easy to find. The wires should be visible but the resistors are inside the plenum. Typically one or two screws holding the block in the plenum. Probably on the passenger side but closer to the center and up higher. Unplug the wires, remove the screws and work the block with the resistor pack out. Maybe try a youtube search as it's likely someone has posted at least a similar repair. For those with cabin filters, it's important not to let it get too junked up. Most of these resistor packs are cooled by air flow in the plenum and a clogged filter can/will cause the pack to overheat and fail. The electronic ones are often rather expensive, upwards to $100 or even more.
