Radiator Fan Meltdown - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2009, 05:24 PM   #1 (permalink)
View Cals95's Photo Gallery
The drivers side radiator fan on my 1995 Camry melted out of it's housing and melted the fan itself.
What would cause this ?
Is it just a bad fan motor or is there an underlying cause that will ruin the new one that I'm going to put in ?
Could there be a faulty sensor that made this motor run wild and over heat ?
Help Appreciated.
Cals95
Cals95 is offline   Reply With Quote
Old 06-29-2009, 05:31 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I've never heard of this. Do you have any pics?
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 06-29-2009, 07:03 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
May be over-current? If so it's a surprise that a fuse didn't catch this. A new assembly should be fine, however will set you back a few bucks. Not sure if you want to go the EBay route, but it's worked for me too.
Help Appreciated.
Cals95
Old 06-29-2009, 08:03 PM   #4 (permalink)
Yes, I have pics.
I just cut the thing out of the shroud and took the pics.
I'm headed home and I will try to post them.
I have never posted pics here since I'm new to this forum, but I'll figure it out.
Thanks for the quick response gentlemen.
Stand by.
Cals95
Old 07-01-2009, 10:32 PM   #5 (permalink)
Here is the Pic of the melted fan.
Used fan and shroud from junkyard, $50
New aftermarket radiator, $135
New rubber radiator feet, $32
3 Hours casual labor.
Technical difficulty of fix, on scale of 1-10, ...about 3.
Seems to run fine.
I think the problem was the motor not the relays or sensors.
Amazing how hot this thing got.
It melted the shroud/support (black plastic glob) as well as the fan.
Thanks for your help.
Cals95
PS This meltdown did blow a 30Amp Fusible Link
The Fusible link is Marked RDI something in the fuse box.
The fusible link for the other fan is marked CDN or something and stands for Condenser fan.
