Car pulls to the right after doing all of the below mentioned... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2009, 11:34 PM   #1 (permalink)
View hassanbigboss's Photo Gallery
I am a little upset with my 1998 Camry V6.......the car has been giving me knocking sounds from under the hood area. I took it to a mechanic and he told me that the car has a broken Sway Bar Link....replaced that costing 100 bucks labor included....
Next thing I did is replace all four tires with 205/65/R15 Kumho Ecsta ASX. The cost for having them shipped from TireRack and mounted + balanced came to $290
Replaced the fuel filter $25 for parts + $30 for labor
I also had the alignment checked and fixed to the proper specifications, costing $15 However, I get a very slight pull to the right. The car was pulling to the right very hard prior to the tire replacement (older tires were Goodyear Viva 2 from Wally World....DONT buy them..complete crap). Anyhow, new tires and an alignment later, I still get a very slight pull.
The mechanic gave me a printout of the alignment:
Front: Left Front: Right
Actual Before Actual Before
-0.4 -0.5 <- Camber-> -0.5 -0.4
0.02 0.09 <- Toe-> -0.02 -0.31
Rear: Left Rear: Right
-0.2 -0.3 <-Camber-> -0.2 -0.1
0.12 0.09 <-Toe-> 0.38 0.36
Mechanic diagnosed that the rear shocks need replacement which btw I agree with because I hear the knocking sound from the back whenever I go over a bump or uneven pavement. So, my question, could the reason for the VERY slight pull to the right be problem with old shocks? (the shocks have not been replaced since the car was purchased in 1998 by the original owner) or is this an issue with alignment? Any input will be appreciated
The car has 193337 miles as of this post
hassanbigboss is offline   Reply With Quote
Old 07-01-2009, 12:10 AM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
You can rotate the tire L/R. If the problem goes to the left then you know. Otherwise could be your right brake dragging? Wheel bearing drag?
Of course we take the alignment numbers at face value.
Old 07-01-2009, 02:13 AM   #3 (permalink)
Hey thanks...I have a hunch that a dragging brake might be an issue...I am going to the mechanic today and will have him check all that good stuff as well. Its just that after spending close to 500 bucks, I am kinda upset at the problem still being there.....maybe Obama can write another stimulus check for me?
