I didn't realize A140E has a differential dipstick tube! Oh well, learn something new everyday. This slipping probably isn't going to be affected by the differential, but it's a good idea to change the fluid there too in general.
The other poster mentioned spark plugs so I suggested NGK Iridium. But sounds more like transmission slipping. Valvoline HM is a good fluid, but if it's line pressure or valve body sticking then it might not do it.
Originally Posted by IrishFBall32
Fluid I used in the change was valvoline maxlife dex/merc >75k formula... I believe I got the differential also because the fill was done thru the differential dipstick tube. ATF levels are still sitting right in the middle of range while hot.
I think I'm going to persue the plugs/wires next... Would that be consistent with this behavior even when everything runs fine even at high RPM most of the time? I also had one of the ignition coils replaced recently due to a crack that was causing misfires during high humidity/splashing... Could it be that the other one needs to be replaced too?
