Need Advice: Lower Ball Joint Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2009, 01:07 PM   #1 (permalink)
View darkwingbenny's Photo Gallery
4th Generation Need Advice: Lower Ball Joint Replacement
1999 I4 Camry, 155K miles
Left lower ball joint is oozing grease and makes a clicking sound when turning the steering wheel. Source of noise was confirmed by being under vehicle and having helper turn the steering wheel.
  1. Any helpful hints on the repair?
  2. Would you recommend OEM parts from the dealer or after market parts?
  3. Are ball joints something that need to be changed in pairs, ie change out the right side while I'm at it?
  4. Any other suspension parts to consider replacing?
Thanks in advance.
darkwingbenny is offline   Reply With Quote
Old 07-02-2009, 02:55 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
If you are keeping the car, change both.
OEM unit is good, but if you want to get aftermarket, go to reputable part store like a NAPA, CarQuest, Advanced, etc and ask for options, usually they will sell economy, service, permium grades of the part.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-02-2009, 04:23 PM   #3 (permalink)
View flyeri's Photo Gallery
You may want to get the alignment checked afterwards. Tell them you just changed the balljoints. Usually they will make sure everything looks good. My guy does at least. See how it drives.
flyeri is offline   Reply With Quote
Old 07-03-2009, 06:13 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
You can get OEM. However, I would also use:
Spicer Profession$32.79, "permanent lubed, easy care":
http://www.rockauto.com/catalog/moreinfo.php?pk=1033011
Moog $40.79, the disadvantage of having to own a grease gun and periodically having to lube it, but a highly regarded brand:
http://www.rockauto.com/catalog/moreinfo.php?pk=204084
Yes. Change in pairs. Also inspect the stablizer bar linkages:
http://www.rockauto.com/catalog/moreinfo.php?pk=1032575
Thanks in advance.
Old 07-04-2009, 09:54 PM   #5 (permalink)
Thanks for the replies. End links were changed recently when I installed Monroe quick struts.
