New intake hose, now rough idle with a CEL on... ***UPDATE - FIXED**
Well, I went to change my accordion style air cleaner tube and resonator with a modified aftermarket one. Well I did so. I removed the assembly and swapped it out with an aluminum tube with 2, 3" Spectre silicone couplers at either end. The install went pretty smooth, I got it all back together. I let the car idle for 10 minutes to check for leaks, none found. I went later this evening to drive the car and it has a lumpy idle now. The CEL popped on. It will run very well under full throttle, and in the midrange, it's just at low rpms that it doesn't idle well. It will move if I want it to, I just don't want it to act this way, plus it also signs horrid when sitting still.
I decided to disconnect the battery and let it sit for a bit to see if the ECU needs to reset and maybe learn the new airflow. I will clean the MAF in the AM.
I was just wondering if anyone had come across this before.
I have a 00 with the 1MZ w/ a 5-speed.
All hoses are connected, checked and double checked.
Thanks
