P401 Insufficient EGR Flow detected on 1999 Camry 4cyl
I have a 1999 toyota camry. Yesturday i got a Check light on my dash. took it in to autozone they pulled a P401 Insufficient egr flow. He told me not to replace the egr valve because it could be clogged or something. I just pulled the entire egr valve off my intake manifold and removed the modulator. The egr valve appears to be working fine. I can apply a vac and the diaphragm goes up. There is no carbon buildup to a point where it dosen't work. I pulled off the modulator as well. WHAT ELSE DO I NEED TO CHECK? Also what other components can cause a p401. The tube going down from the egr seems to be fine as well. How do I check the modulator.
I was reading online and it appers the modulator gets bad often??
Suggest you visit the AutoZone website's vehicle repair guide section on this car. The site should have info on how the system works and troubleshooting.
Did you also check the steel tube connected to the valve for plugging and the VSV valve?
Try testing the modulator. Apply vacuum to the bottom port of the modulator and if it does not hold vacuum, then your modulator needs to be replaced.
It could also be the VSV, vacuum switching valve or your manifold or throttle body is clogged.
Open the top of the modulator and pull out the filter media. If it has a round black spot the modulator is probably toast.
UPDATE
I removed the modulator and EGR valve. I cleaned them out. I pulled hte cap off the modulator. I noticed a black spot on the modulator where the hole meets the filter. I put them back and bolted everything up. I pulled the battery cable and put it back. The light hasen't came on since. I've been grocery shopping etc. I spent around 5 miles or so and the light hasen't came on. IDK.... Also what chemical should I use to remove build up carbon. seems the brakcleaner I was using withich usually is good at grease dosen't work well on carbon.
I also notice there wasen't much in there I mean it wasen't really dirty. I didn't check the VSV nor the tube that goes from underneath the engine to the EGR valve.
hi
i had the same problem and i clean the egr valve and change the egr modulator and then took the bettery terminal out. the light went out but after driving about 400 miles and guess what... light came back!
so my point is that you need to check your vsv valve which only accessible from under the engine threw right wheel..which very common to go bad on a camry (at least according a lot of thread on this site) can be check with the multimeter for resistance (which should be in the specification) anyways, if you need pic for where vsv located....i don't have a 99 Camry but do have for 96 Camry so let me know
forgot to mession one thing clean ur egr valve with either sea-foam deep creep (expensive ) or any carbon cleaner ....and if u do find out that vsv is bad i got mine from murrays website part#EGR287 with LLT warranty (cost 65.99+ shipping)
I've got a similar problem on a 2000 Camry LE 2.2 L 4 Cylinder. Following everyone's advice, I replaced both the EGR VSV and the EGR Modulator. However, I'm still getting the P04/01 code.....does this pretty much narrow it down to the EGR valve itself? Any help would be much appreciated!
one thing nobody else mentioned is the EGR temperature probe. i don't know about the 4cyl's, but in the v6, it's a probe that screws into the side of the egr valve. it's how it knows exhaust gas is actually flowing or not. if this temp sensor is bad, has a bad connection, or something like that, then it will throw the EGR insufficient code. i learned about this little guy while doing my s/c in my 95...
__________________ 98 Camry CE v6 5s 97 MX-5 95 Camry SE v6 2dr SC (sold) www.gibson99.com
no, you would get misfire, lean, or rich codes from ethanol because it lowers the octane rating of the fuel. octane and knock have no effect on the egr system. and even then you'd have to run pure E85 instead of regular gas (which only has 10% ethanol, not 85%) to cause problems.
