I use pressure bleeder, and I don't keep any fluid in the jar (bottle really). If you do that you have to make sure the bleeder screw is closed before your helper releases the pedal. Also put a block of wood under the pedal to limit pedal travel (to protect the master cylinder piston cups into less used areas).
There are plenty of DIYs out there for the Google. Here is one from Advance Auto, look at the "Step-by-step" tabs:
http://www.advanceautoparts.com/engl...20011001bb.asp
According to Haynes manual, if only one caliper is loosened you can do just that one. But I'd recommend that you do all four and follow the proper bleed sequence (usually RR, LR, RF, LF, check manual to be sure). It takes about 1 qt to do all four.
It's never recommend to drive a car with a less than perfect brake system.
Originally Posted by bud659
dumb question from the new guy  but can the jar with the clear tubing be empty? and i have a 1/2 pint of brake fluid left, do you think thats enough? never done this before. thanks!
