Center console removal HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2009, 02:00 AM   #1 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
i cant seem to disconect the center counsol....like anything i pulled out 2 10mm bolts ok then i started breaking plastic...nothing visable whats the trick im trying to get in the shifter area
thanks
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 07-04-2009, 02:48 AM   #2 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
with a flat screwdriver, pop off the lid around the shifter, then you'll have 2 phillips screws, remove these two and you should be able to remove the armrest part... then for the cup holder and ashtray and shifter, there should be screws hiding in the foot well each side behind the lower kick panels...
I'm going from memory, sry i don't have pics...
CamryWilly is offline   Reply With Quote
Old 07-07-2009, 10:37 PM   #3 (permalink)
how do you remove the cup holder?
Old 07-08-2009, 12:11 AM   #4 (permalink)
tankf2008's Avatar
View tankf2008's Photo Gallery
3rd Generation
it comes out with the entire piece but the ashtray u might need to remove
1994 toyota camry v6 xle - stock - 5-speed swap in progress should be done in a few days
and
1998 dodge ram 2500 3/4 ton 2wd - everyday hauler until the camry is up and smoking hondas
tankf2008 is offline   Reply With Quote
Old 07-08-2009, 12:35 AM   #5 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
The cup holder in my 96 Camry just sort of pops out with force. Other than that you have the screws under the shifter cover. It's quite easy to remove actually.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
