2000 Camry, Help with water on floor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2009, 09:16 PM   #1 (permalink)
View GH05's Photo Gallery
I just got back from a long trip with my 2000 camry 4cyl. It was very hot,the air was running for several hundred miles, no rain the whole weekend. Near the end of the trip I noticed about an inch of what appeared to be water on the drivers side rear floor. The carpet is wet on both sides front and back, but more on the drivers side. It appears dry near the gas and brake pedals. I assume this must be from the air conditioner. I cannot see any dripping. Any help on where to look would be appreciated. Also, what is the best way to check and clean the air conditioner condesation tube. Is it done under the dash? I have heard of blowing it out with compressed air from underneath the car. I am not sure the condensation tube is the problem. Thanks
GH05 is offline   Reply With Quote
Old 07-04-2009, 09:51 PM   #2 (permalink)
Also, can anyone telll me where to locate the condesation tube inside the car, ? driver or passenger side, ? does it run under the carpet? Thanks again
Old 07-05-2009, 01:28 AM   #3 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
The tube runs stright down fromt he dash into the floor pan. It's between the PAss and drivers foot wells where the shifter cable runs.
5 Lug Corolla WHAT?
Old 07-05-2009, 05:31 AM   #4 (permalink)
are there any connectors or a common place for it to leak? Does the console have to be removed to get to it? thanks
Old 07-05-2009, 09:52 AM   #5 (permalink)
Sometimes crap can get into the tube which will cause it to plug up. You'll need to lift up the carpet (of course), along with everything over the carpet. There are pieces to the dash you have to take off to get the carpet out, but not the main dash. Let me know if you want me to make a quick DIY for you.
5 Lug Corolla WHAT?
Old 07-05-2009, 11:04 AM   #6 (permalink)
I would really appreciate a quick DIY if you would be so kind.
