Engine RH Mounting Bracket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2009, 04:39 PM   #1 (permalink)
View TheDust5's Photo Gallery
I have a 1994 Toyota Camry with the 1MZ-FE engine and it was having problems overheating
I later found out it was the water pump is leaking so i figured get a new one and install it and do the timing belt while i was at it.
anyways everything was going good until i got to the Engine RH mounting bracket, i took out all the nuts and bolt and when i went to pull it off it's stuck, theres nothing attaching it to the engine and it will pull off about 3/8th an inch but no more. does anyone have any idea on what to do?
TheDust5 is offline   Reply With Quote
