Originally Posted by N35QU!K
You mean heat insulation? There's this material called heat wrap, which I imagine can be found at the average hardware store, but seeing that you're in Saudi Arabia, I have no idea where you might obtain heat wrap.
It might not make much of a difference though, as engine bay temperatures usually exceed 110F under normal use
thanks for the input man, i have those heat wraps the kind that go on headers, but the thing is i'm not aiming to insulae the intake pipe, i want something similer to what come with K&N cold intakes, you know, to insulate the filter so that it sucks in cold air only
and about that 110F engine bay temp, that goes for american specs camrys (like mine), you should see the gulf specs camry, the fans are programmed to work at a much lower temperature, as a result the coolant heat gauge only goes up to the first quarter, and you can actually feel a big difference when u open the hood!!!
