leaking oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2009, 10:27 PM   #1 (permalink)
View my name is joe's Photo Gallery
4th Generation leaking oil
i looked around and it seems like its coming from the oil pressure switch. there seems to be oil dripping from there and when i took it out it was wet. http://frugalmechanic.com/auto-part/...tch-with-light
is that the right part? and whats the "with light" about?
i could not find the part online anywhere. can anyone help me on where to buy this part? amazon sells it for cheap but im not sure if thats the right part.
1998 camry le 2.2
my name is joe is offline   Reply With Quote
Old 07-07-2009, 10:44 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Where is it leaking from? O-ring? Connector? Is your PCV system working? Just make sure it's not your crankcase doesn't have vacuum.
Well, rockauto.com has them 20-27. Don't know what light? Don't they all (Oil Low light on dash)?? Check connector style I suppose.
W/Light:
http://198.208.187.182/internet/Part...partnbr=E1805A
http://198.208.187.182/internet/Part...artnbr=212-385
1998 camry le 2.2
Old 07-07-2009, 10:54 PM   #3 (permalink)
i also found this
http://www.autozone.com/autozone/cat...061&questions=[]
if its available at autozone i might as well go there.
i THINK its at the connector. i brought it to a shop and he took a quick look at it and told me it was the switch. and i asked him thats all i had to do? he said yup and said it was simple to do so i dont have to bring it to him and charge some silly price for twisting off a screw.
Old 07-08-2009, 11:38 AM   #4 (permalink)
Gameroom cash: $303255
Oil pressure switches require a special socket. (Notice the grooves around the hex in the picture.) A regular socket won't work. If you are going to Autozone they will probably loan you the socket. Be sure to ask for it.
Mike
Old 07-08-2009, 01:03 PM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
22mm box end wrench or O2 wrench/socket will do.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-08-2009, 11:59 PM   #6 (permalink)
Whats wrong with a regular adjustable wrench? I used it to switch it out and it worked flawlessly. It was easy as well the oem switch had so many grooves i didnt have to stretch so far to keep turning it. I changed it out for a duralast and that had the traditional sides of a hexagon. No problem whatsoever changing it.
Old 07-09-2009, 06:23 AM   #7 (permalink)
"I changed it out for a duralast and that had the traditional sides of a hexagon."
Interesting. Hopefully it stopped your leak.
Mike
Old 07-09-2009, 04:05 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
This one
Light switch
skewe is offline   Reply With Quote
