93 camry brake line help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2009, 12:10 PM   #1 (permalink)
View osogreat1's Photo Gallery
Where can i find brake lines that to replace my old ones? i got a 93 camry sedan v6
osogreat1 is offline   Reply With Quote
Old 07-08-2009, 03:03 PM   #2 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Autoparts stores sell lines, you have to bent them......(with tubing bender!!!)
you also need a tubing bender, flare kit, tubing cutter......
and fittings
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 07-08-2009, 04:36 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
and fittings
Remove your old line and take to the auto parts store. Have them match up the thread size, fitting type and approximate length you will need. They are bendable by hand. A tubing bender is not required. If your replacing a very long line, you would need a flaring tool, fittings, spool of hard line, etc. Which line are you replacing?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 07-08-2009, 04:41 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
Are you talking about the rubber lines from the fender to caliper or hard lines?
frenum49 is offline   Reply With Quote
Old 07-08-2009, 08:11 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
All parts stores, including your local NAPA should carry them. I wonder if there is a difference in SAE or Metric depending on where the car was made.
Metric double-flare tools may be hard to find. SAE ones are cheap all over. And you can borrow them on free loaner tool programs in some parts stores.
Here is a DIY on double flare:
http://www.pharmacy.arizona.edu/staf...ubleFlare.html
Old 07-08-2009, 08:14 PM   #6 (permalink)
Another one is go to the dealer and order a specific one. May come as pre-bent. $$$
Old 07-08-2009, 10:04 PM   #7 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i bought mine prebent from the dealer. price wastnt too bad - well worth saving the headaches of bending it myself and possibly kinking a line.
Old 07-11-2009, 08:31 AM   #8 (permalink)
thnaks for all the help..im going to go ahead and check out the auto parts store.
Old 07-11-2009, 01:12 PM   #9 (permalink)
i actually found out exactly what i need....i need the steel lines and the part where the steel connects to the rubber hose i need that part...all the steel parts are rusted in the back even the metal part that looks like a spring...(sorry dont know the names of the parts)
Old 07-11-2009, 04:42 PM   #10 (permalink)
There usually is a curved spring clip that hold the rubber hose to a piece of welded bracket. Is this what you're talking about? Most of the time they can be reused.
If you need to replace all lines then check with your local dealer on price. It'll save you time bending all the lines.
I'd highly recommend that you get a torque wrench and a metric/sae flare crowfoot. This way you can properly torque down the flare nuts without stripping the soft metal.
< $15 on sale frequently:
http://www.harborfreight.com/cpi/cta...Itemnumber=807
Metric flare crowfoot set:
http://www.harborfreight.com/cpi/cta...emnumber=47928
Old 07-11-2009, 05:35 PM   #11 (permalink)
okay thanks alot
