Gen 3/4 Rear Hub Replacement DIY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2009, 11:38 PM   #1 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
1: Unscrew the bolt that holds the brake line to the strut.
2A: Unscrew the bolt (12mm) that holds the caliper to the caliper bracket.
2B: Lift the caliper up off the brake pads.
2C: Pull the caliper off the bracket, and lay it on something. The floor is good if the hose is long enough. But try not to let it hang by the hose.
2D: Take out the old pads.
3: Unscrew the 2 bolts (14mm) holding on the caliper bracket.
4: Pull off the rotor.
5A: Unscrew the 4 hub bolts (14mm).
5B: Simply pull out the hub.
6: Screw the hub back on with the 4 bolts (59ft/lbs)
7: (Recommended, not needed though) Spread Antisieze on the hub to prevent the rotor from rusting to the hub next time you take it off.
8: Screw the Caliper Bracket back on (34ft/lbs Torque)
7: Put in the new brake pads.
8: Slide the caliper back onto the caliper bracket slider pin.
10: Screw the caliper bolt back on. (14ft/lbs Torque)
5 Lug Corolla WHAT?
Old 07-09-2009, 01:36 AM   #2 (permalink)
View Camry LE 94's Photo Gallery
Excellent DIY! thanks!
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 07-09-2009, 01:50 AM   #3 (permalink)
Hi.
View mystickid's Photo Gallery
Wonderful write up.
Thank you!
mystickid is offline   Reply With Quote
Old 07-09-2009, 04:05 AM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Good Job Adam!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 07-09-2009, 07:24 AM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Great DIY! Excellent pictures!
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
