Can I reuse stock springs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2009, 02:39 PM   #1 (permalink)
View Agrippa's Photo Gallery
So this is for my 97 Camry LE 4 cyl. I am a poor college student and this is my one and only car. I bought it in hopes that it will see me through at least for the next 2 years/50,000 miles.
The problem with the suspension currently is the strut mount bushings. They make a god awful squeaking/clunking noise going over even the smallest bumps. The shocks are also a bit worn and dont dampen as much as it should, but they're not blown/leaking.
Right now, other than the car handling like a boat, it drives fine. However, if I were to change the strut mounts and shocks, i was wondering if I could reuse the springs without a problem. Like I said, I am a poor student so I am trying to just keep the car in working order, nothing fancy like coilovers or high spring rate springs, etc.
Thanks.
Agrippa is offline   Reply With Quote
Old 07-10-2009, 03:38 PM   #2 (permalink)
the honda killa
rholzboog's Avatar
View rholzboog's Photo Gallery
change the springs trust me i did it and had to take it apart and redo it
catch me if you can
rholzboog is offline   Reply With Quote
Old 07-10-2009, 04:24 PM   #3 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
If all you're concerned with is a comfortable quiet ride, you can reuse the stock springs. as long as they aren't rusted to pieces, there's nothing wrong with reusing them.
front upper strut mounts had a TSB or three on them for the knocking/clunking noise. toyota redesigned them a few times but never completely eliminated the noise. don't get me wrong - it got a LOT better, but it still clunks now and then, mostly in parking lot type situations.
as long as your car isnt' bouncing uncontrollably, i say keep the existing struts, too. just install a new set of front upper strut mounts, and don't forget to grease the strut bearing when reassembling.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
