95 camry outer tie rod end question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2009, 01:37 AM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
3rd Generation 95 camry outer tie rod end question
me and some one changed my outer tie rod ends and on the passenger side and the toe is way off it is out.im sure that he threaded the tie rod end on too far about 9 or ten turns maybe more. do i need to take it back apart and redo the outer tie rod end or can the alignment shop fix this and still have my sterring wheel straight.or do i need to need to take it back apart? thanks
stlwil is offline   Reply With Quote
Old 07-13-2009, 01:42 AM   #2 (permalink)
View 500KCamry's Photo Gallery
Let the alignment shop do it. Don't drive much till its done to save your tires.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 07-13-2009, 07:37 AM   #3 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
Just to warn you.... The alignment shop probably wont do much with the car if they find you need other suspension work like ball joints, inner or outer tie-rod ends, wheel bearings etc.
frenum49 is offline   Reply With Quote
Old 07-13-2009, 09:23 AM   #4 (permalink)
stlwil's Avatar
thanks im on my way to firestone i only went 1.3 miles with sterring out of wack and i need to go about 5 to the shop.
Old 07-13-2009, 09:58 AM   #5 (permalink)
View flyeri's Photo Gallery
For a rough fix you can measure with a tape measure from spots on the tread at identical height front and back of the tire. Adjust to the same measurement. I have measured, change one side and that side adjust to proper measurement, change other side and adjust second side to good measurement.
But no more than 5 miles or so will not hurt a thing
flyeri is offline   Reply With Quote
