acceleration problem/ rpm high 94 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2009, 05:18 PM   #1 (permalink)
View plush650's Photo Gallery
Talking acceleration problem/ rpm high 94 camry
hello everyone this is going to be my first post. I have a 1994 toyota camry coupe v6 le with 88k miles on it. Problem is that when i put it on "D" (drive automatic) it seems that the car struggles to get to 2nd gear and i have to baby the gas pedal. It will change to 2nd gear in between 4k - 5k rpm. and plus no acceleration power on 1st gear to 2nd gear. It drives smooth when i go over 50-60 miles and it runs like a champ. Im just wondering what is the problem. I went googling and no straight answer. i just hope that its not a tranny problem. any suggestions will help thanks!
plush650 is offline   Reply With Quote
Old 07-13-2009, 06:53 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Check your transmission fluid. If its dirty, do a drain and fill. If its low, top it up and see if it gets better. I would think the trans is slipping if you have no power or acceleration from 1st to 2nd. Will it shift any lower than 4k or always between 4k and 5?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 07-13-2009, 07:41 PM   #3 (permalink)
thanks for the quick reply. yeah i have changed the tranny fluid and no improvement. when i go pass 1st gear everything else goes smoothly. only on the 1st gear going on 2nd i have the rpm shoots to 4k to 5k before changing gears.
Old 07-13-2009, 08:16 PM   #4 (permalink)
Gameroom cash: $498830
View JohnGD's Photo Gallery
Yeah, that sounds like your transmission is slipping. Try shifting into "2" and see if it behaves differently? Don't go over about 20 MPH in "2", it should be enough to test out the first two gears.
