Hi, everyone
I'm new to this forum, and purchased a secondary car (1 week ago) since my prior one was totaled a few months ago. I'm glad I purchased the Camry as it is a great car so far, but have a few quirks to work out.
Car: 1998 Camry LE 4cyl
Mileage: 138,000
Problem existed before all the below was performed.
I have done quite a few maintenance items thanks to some threads on this board such as:
- Timing Belt,
- Water Pump
- Idler Bearing
- A/C Belt
- PS Belt
- Valve Cover Gasket
- Spark Plug Tube Seals
- Crankshaft Seal
- Oil Pump Seal + O-ring
- Thermostat + Gaskets
- PCV Valve
- Spark Plugs
- Transmission + Diff Fluid
- Chevron Techron Fuel Cleaner
- Radiator Fluid
Problem:
During cold starts in the mornings, the car starts fires up, but stumbles very hard until it is warmed up (car feels like its going to die). The RPM drops to around 300-400 rpm, until it is warmed up (after a few minutes it is fine, goes back to normal idle around 750rpm). The rest of the day the car starts up fine, just when the car sits overnight and started the next morning I experience this.
Attempted Solution:
I have cleaned the throttle body with throttle body/intake cleaner, and also sprayed some down the IAC hole before the plate (did this quite a few times, also disconnecting and connecting the connector to allow the valve to open and close).
Anyone know what might be the underlying cause of this problem? I'm lost on what else to check.
