Horrible on gas and high idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2009, 07:01 PM   #1 (permalink)
View wannabwrc's Photo Gallery
Hey guys,
I recently swapped a 5sfe motor in my camry. It has been horrible on gas since and it has a high idle when in park. Around 1k-1.2k. I swapped it because my friend who previously owned the car blew the head gasket. So i swapped a whole block. I am wondering if my timing is off on the distributor, thus making it bad on gas. (I swapped the distributor too) Its not throwing any codes at this time, and there are no vacuum leaks I can find.
Any help would be great,
thanks!
wannabwrc is offline   Reply With Quote
Old 07-14-2009, 07:56 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
If the timing is too far advanced, it will idle higher and use more fuel. Check the bolt on the distributor. If its not near the center of the adjustment channel, loosen the bolt and get it as close to the center as possible. That will get you close to 10 degrees BTDC. Then get a light and fine tune it. Check that your throttle cable is properly adjusted. I had a similar problem when I put the TB back on my Camry. The cable was holding the butterfly open a little because I didn't set it right and my idle was higher than normal.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
