power steering pump BELT noise. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2009, 09:54 PM   #1 (permalink)
View derick's Photo Gallery
Hello,
After change the power steering pump BELT for my 1997 Camry 4 cylinder, when I turn all the way to left or right, and hold the it, I hear the noise, if I don't turn any, it will be fine, not noise. Before I changed the belt, it does not have any noise.
I check the belt is tire. but I don't know how much tire show be right, maybe it's too tire?
Thank you,
Derick
derick is offline   Reply With Quote
Old 07-14-2009, 10:05 PM   #2 (permalink)
update:
when I turn all the way to left or right, I saw the belt is stop a while, is it not tire enough?
Thank you,
Derick
Old 07-15-2009, 12:23 AM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
I would think the belt is still loose. Check your tension by twisting the belt side to side. If you can twist the belt more than 45 degrees, its too loose.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 07-15-2009, 09:18 PM   #4 (permalink)
View Default User's Photo Gallery
Not sure on a 4cyl, but my 92 V6 had 3 different PS belts depending on the VIN number at the dealer.
Did you get an aftermartket PS belt or OEM?
Default User is offline   Reply With Quote
Old 07-15-2009, 10:09 PM   #5 (permalink)
View 1996camry's Photo Gallery
i have similar problem like yours... it turns out the power steering belt was loose. here is how to check to see if your belt is loose.
use your thumb press to see if you have a lot of loose tension... if you do, re-tight and the problem will go away...
power steering on my car that made the noise when turned the steering all the way to the left or right..i heard the noise...
i re-tight the PS belt, the problem went away.
hope this help you a little...
1996camry is offline   Reply With Quote
Old 07-15-2009, 11:55 PM   #6 (permalink)
Thank you Paseo, I will check it out tomorrow.
Thank you, I get an OEM belt from the dealer.
Thank you, This is very helpful, I will check it out tomorrow. I check my sienna's ps belt, looks a lot tighter than the one I did in my camry.
Old 07-17-2009, 12:11 AM   #7 (permalink)
update:
The belt still loose. re-tight the belt it works, Thanks all.
Derick
