2001 Camry Rear Window Stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2009, 04:41 PM   #1 (permalink)
01 Camry LE 5S-FE
View stefan27UF's Photo Gallery
Hello all!
I've got a '01 Camry with a bit of an annoying problem. I can roll down my rear window no problem though when it comes back up it gets stuck about 3" or so from the top. If I wait a while, and repeatedly press the button to get it to go up it budges up a little bit. Most times I have to press the button and apply a bit of force on the window to get it to close. It seems to go down smoothly, and rises steadily up until this point. Could it be something inside the door blocking the window or do you think the motor could be dying on me?
stefan27UF is offline   Reply With Quote
Old 07-15-2009, 05:04 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Sounds like the window regulator. Power windows are so expensive to repair
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 07-15-2009, 09:44 PM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
^^ sounds about right to me. The window regulator is one of the most common failures on Camry's, I had 2 fail on my car. Replacement isn't as expensive as it is a pain in the rear end... Look up the regulator on ebay, and here is a DIY, should be roughly similar for your car: DIY Replace Window Regulator - Camry 92-96 & Equivalent Models
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 07-16-2009, 04:51 AM   #4 (permalink)
^ Thanks for the link. The regulator on my mom's gen 3.5 is starting to make noises when you put the window down. I'll keep an eye on it and replace it if need be. Maybe with the help of my cousin since he's got half a garage full of tools
moving forward
Old 07-16-2009, 07:22 AM   #5 (permalink)
01 Camry LE 5S-FE
Thanks for the input! I guess I'll look into replacing the regulator then. I've taken apart the front driver's door before to replace the door handle before and that was a pain. But other than removing the interior handle, this doesn't look too bad. Again thanks for the help!
