94 Camry Engine dies in drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2009, 06:41 PM   #1 (permalink)
View hermsky's Photo Gallery
Unhappy 94 Camry Engine dies in drive
I have a 1994 Toyota Camry with 160k 2.2 4 cyl
The car starts and idles perfectly, you can rev the engine as high as you want in park or neutral and it is smooth and responsive. When I put it in drive or reverse and move the accelorator pedal it stumbles and dies. If I put it in gear and let it idle without pressing the pedal it will drive anywhere you want to go at 3-5 miles per hour without a miss or engine stumble. But as soon as I appy pressure to the pedal it stumbles, coughs and dies.
Does anyone have any ideas?
Thanks,
Scott
hermsky is offline   Reply With Quote
The Following User Says Thank You to hermsky For This Useful Post:
Savio (02-15-2012)
Old 07-16-2009, 07:39 PM   #2 (permalink)
A.K.A WALDO
wald0's Avatar
View wald0's Photo Gallery
change of spark plugs maybe? tune up? that happen to mines before, when i would accelerate it would struggle den die.
wald0 is offline   Reply With Quote
Old 07-16-2009, 08:26 PM   #3 (permalink)
Tried the tune up but didn't work
Plugs are OK, Cleaned the intake.
Also changed the gas filter.
Just don't know??
Thankl for the reply! I appreciate it!
Scott
Old 07-16-2009, 09:33 PM   #4 (permalink)
View davemac2's Photo Gallery
It may be your torque converter lockup clutch is stuck on due to a bad lockup solenoid or something.
Are you positive all cylinders are firing? Maybe one of your injectors is bad?
Have you checked your alternator output and battery health?
dave mc
davemac2 is offline   Reply With Quote
