weird problem with alarm system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2009, 04:20 PM   #1 (permalink)
View kevinf1990's Photo Gallery
i have a 1999 toyota camry with the factory alarm system. today when i went to lock and unlock the doors, the alarm didn't chirp. it usually chirps once when locking and twice when unlocking. the red light that usually blinks when the car is armed now blinks even when the car is unlocked. does anybody know how to fix this problem?
kevinf1990 is offline   Reply With Quote
Old 07-17-2009, 04:36 PM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Does your system have a button you can push?
My 2000 camry alarm has the red light doubled as a on/off push button switch. When the alarm goes off while armed, it blinks constantly to tell me that the alarm went off. To turn it off, or reset the system, I have to put the key in and turn to the 'ON' position and push the button 8 times and then car honks and flashes.
Hope that helps.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 07-17-2009, 04:52 PM   #3 (permalink)
thanks a lot that worked. although the button on the 1999 is close to the hood release latch. but thanks
Old 07-17-2009, 05:13 PM   #4 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Is the factory system really that elaborate that you have to manually reset it each time the alarm goes off? I've got an aftermarket DEI/Viper system and the LED blinks to indicate which zone was triggered and then resets when you turn the ignition to "ON" - the last few alarm triggers are stored in flash memory and can be read with DEI's bitwriter or whatever they use.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
