fuel injector removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2009, 11:13 PM   #1 (permalink)
View murphymp's Photo Gallery
Hi,
94 camry le 4 cylinder
What parts do I have to take off to get to and remove the fuel injectors in my car?
Thanks.
murphymp is offline   Reply With Quote
Old 07-17-2009, 11:49 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Taking out the intake tubing would make it a lot easier.
The 2 fuel lines in it (obviously). For the line in, it would be easiest to remove from the fuel filter.
There are just 2 screws holding the rail onto the head.
5 Lug Corolla WHAT?
Old 07-18-2009, 02:18 AM   #3 (permalink)
View 500KCamry's Photo Gallery
Originally Posted by murphymp View Post
Hi,
Thanks.
Pull the valve cover to access the electrical connectors easier. Change the gasket if needed, or be prepared to silicone by the cam endpoints when you replace the cover.
You'll need to replace all the seals on the injectors, a kit is available.
If you remove any of the banjo style fittings on the fuel filter and fuel pressure regulator, you'll need new copper crush washers.
If you pull the air intake, you'll need a new gasket for it.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 07-18-2009, 02:51 AM   #4 (permalink)
^ What? The air intake doesn't have any gasket. It's a rubber tube.
5 Lug Corolla WHAT?
Old 07-18-2009, 08:26 AM   #5 (permalink)
So you can get to and remove the fuel rail and injectors by taking off the only the valve cover? Have you done it this way before? I just found in my shop manual and the procedure they list says to take out the intake manifold.
Also, where do you buy just the copper crush washers? The Stealer?
Thanks.
Old 07-18-2009, 09:28 AM   #6 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
I think he means between the intake manifold/plenum chamber and the head.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
