programming remotes and is there a max number of remotes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2009, 01:12 PM   #1 (permalink)
STUFF
View stgranger's Photo Gallery
Hello! I have a 98 ES300 with automatic locks and I am trying to program 2 factory remotes for the car. I found instructions and one of them worked just fine, but the other one won't program.
Before I try to return it to the ebay seller, I was wondering if maybe there is a maximum number of remotes that can be programmed for the car. I don't have the old remotes anymore so I wouldn't mind clearing all the remotes and reprogramming just these 2 if that is possible.
I don't know if the sequence for programming for a toyota and a lexus are teh same, but if somebody knows whether or not there is a max number of remotes that you can program for the camry, that could be helpful.
Thanks in advance for your replies!
Scott
93 Toyota MR2, 88 Mazda RX7, 69 VW Bug
STGranger@cox.net
stgranger is offline   Reply With Quote
Old 07-18-2009, 08:10 PM   #2 (permalink)
View 05DCLB's Photo Gallery
Pretty sure its four.
05DCLB is offline   Reply With Quote
Old 07-18-2009, 11:51 PM   #3 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
agreed. 4 is the max for all the factory toyota ones i've programmed. however, clearing old ones isn't usually needed. say you program remotes A B C and D. When you program remote E, it will erase A and leave BCD in memory. Program F and it will erase B, and so on. wouldn't hurt to clear all of them tho, for safety reasons.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 07-19-2009, 12:06 AM   #4 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
4 is the most. as gibson said, its better and recommended to clear all remotes and program them in one at a time again. i was unaware of the abcd scenario, i thought that you had to clear it all at once and then reprogram each one.
iovaykind is offline   Reply With Quote
Old 07-19-2009, 08:50 AM   #5 (permalink)
STUFF
Thanks everyone for the replies. It sounds like that might be my issue. I will see if I can figure out how to clear the remotes and let you know if that's what it turned out to be.
STGranger@cox.net
