Ksport spring preload - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2009, 11:28 PM   #1 (permalink)
PRSRIZD
MyFreeCamry's Avatar
iTrader Score: 6 reviews
View MyFreeCamry's Photo Gallery
So after installing my CO's and driving around for a bit. At low speeds in parking lots and while turning at low speeds, I am getting a lot of spring popping and pinging. How exactly do you adjust the spring preload and what is the best setting for it?
1990 Yota truck - 2wd 4spd, 22r. Lowered 5", 17" Ford Escape rims, flat green paint.
1992 Camry - Going back to stock. GONE View my parts for sale - http://www.toyotanation.com/forum/sh...47#post2908847
MyFreeCamry is offline   Reply With Quote
Old 07-20-2009, 05:16 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
I usually put mine half way between, only because I do like the response, but jesus, if you leave it all the way to "stiff", you'll feel a damn penny if you drive over it
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 07-20-2009, 05:47 AM   #3 (permalink)
Gameroom cash: $283230
View LE05's Photo Gallery
if the Ksports are anything like the BC Racing coilovers, you'll have two lock rings under the spring. loosen the bottom one to unlock the rings... then bring the top one up to increase the preload. once that is done, bring the bottom ring flush with the top ring to lock it. you do not want to increase the preload by too much... because you'll be changing the spring rates at that point. BC Racing recommends a maximum of 5mm of preload on my coilovers, Ksports are probably similar.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 07-20-2009, 08:28 AM   #4 (permalink)
PRSRIZD
Knailgun, you are thinking of the damper adjustment. fronts are half, rear are full, for me. I don't mind the "harsher" ride.
LE, thats exactly what I thought, just wanted to make sure. I don't know where they are at right now, all I know is that the pinging has to do with the spring preload, and it just isn't right.
Old 07-20-2009, 08:41 AM   #5 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
dont ever preload your springs, unless you want to blow your struts in a few weeks
make sure the perches lock on the springs tight, that's about it
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is online now   Reply With Quote
Old 07-20-2009, 01:13 PM   #6 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
just tighten them up a small amount from how they were set ... they are functionally at 0 preload, so they come loose once in a while, keep them tight and you should be ok
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
