Oil Leak. Not Sure Where From? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2009, 06:05 PM   #1 (permalink)
decrypted's Avatar
View decrypted's Photo Gallery
USA Oil Leak. Not Sure Where From?
I Have A 93 Camry (3vz-fe) 250.000mi. I Just Replaced The Oil Pan Gasket With Rtv. Because It Was Leaking From What I Thought Was The Oil Pan, But It Is Still Leaking. I Had Just Recently Replaced The Head Gasket And Its Not Coming From There. It Is Just On The Passenger Side. There Is Oil Getting On The Drive Shaft So It Is Just Spraying It Every Where. It Is Losing About A Qt, A Week. Need Some Help to Figure Out The Problem, Also The Head Gasket Blew Because Of Overheating.
decrypted is offline   Reply With Quote
Old 07-20-2009, 06:15 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Check the valve cover gasket and the distributor gasket.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 07-20-2009, 08:43 PM   #3 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Make sure it's oil. I was leaking from this spot and waited for about 2 weeks to see if my oil level went down, it didn't. My power steering hose was cracked.
Here are some tests to try:
Get some freshly dripped fluid and put it on your finger. If it has a red tint, it's the power steering.
Turn the car on and put cardboard under your car. Turn the steering wheel from left to right (all the way on both sides) for about 2 minutes. Turn the car off and look under. If it's the power steering hose, it should have sprayed onto the cardboard. (Turning the wheel runs puts pressure in the hose, and it sprays.)
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 07-22-2009, 02:04 AM   #4 (permalink)
decrypted's Avatar
i checked the valve covers and head, there clean. there is a little oil under the distributor. so im thinking it might be the main crainkshaft seal.im going to cheak the cam oil seals tomarrow but i dont think its leaking from there, hopefuly. is there any other seals around there it could be?
Old 07-22-2009, 02:11 AM   #5 (permalink)
decrypted's Avatar
im sure its not the power steering cause that fluid level stays the same. but oil, i have to put in about two qt's. a week. i think im going to power wash the undercarrage of the car. drive it a little and then check it out.
Old 07-22-2009, 07:06 AM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
the amount you are losing, my guess is the oil pump. just curious, losing a quart a week, can you tell if the leak is worse when the car is running as opposed to when its off? can you see it dripping on the ground after the car has been running for about 10 minutes, but then the drips slow down after the car is off?
Old 07-25-2009, 05:44 PM   #7 (permalink)
decrypted's Avatar
that is exactly what it is doing. when we start the car and go for a drive,even just a short drive a few miles. It will start leaking and when i turn it off it will start slowing down after a min. so i think your right. is there just one seal it could be or i is there another one. the owner of the vehicle wants me to just put RTV on it to fix the leak but i don't think that will work cause it is under pressure.
