5spd engine revs on shift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2009, 07:52 AM   #1 (permalink)
Gave in to Toyota
View rmarles's Photo Gallery
Canada 5spd engine revs on shift
Hi There,
1998 Camry, 2.2, 5spd.
Under load, if you depress the clutch pedal to change gears, most times, the engine keeps the revs up (2-4 seconds) before coming down.
It's wierd, almost like a sticking throttle cable or something, but it's not.
I tried replicating it on a standstill to confirm if the throttle cable was sticking, but with no avail. The only time it does it is after a load has been applied to the motor, and you're releasing the load by depressing the clutch.
Not really a big deal for acceleration - but if you're slowing down, you're almost fighting this as you go backwards through the gearbox...
Anyone else hear of this? Any suggestions?
rmarles is offline   Reply With Quote
Old 07-21-2009, 09:55 AM   #2 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
Congratulations, You have discovered Inertia!!!
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 07-21-2009, 10:10 AM   #3 (permalink)
Gave in to Toyota
yuk yuk yuk.
Seriously though, it's not intertia. If it was, I'd be able to replicate it at a standstill.
If I bring the revs up while parked, hold it at say 2000rpm as if I was cruising (except with the clutch fully disengaged), and let off the gas, the revs drop instantly.
If I'm cruising at 2000rpm, let off the gas and fully disengage the clutch, the rpms don't fall at all for almost 4 seconds.
Thanks in advance
Old 07-21-2009, 10:48 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
is the engine rev matching for you?
but in all seriousness....I would check for carbon in the throttlebody, or a sticky throttle body in general. also check the iac and as you mentioned, the throttle cable as well
and if you have cruise control, check that also. my gf had that problem on her malibu before and the problem was actually inside the cruise control unit
HaHa
