1998 Camry ABS light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2009, 04:42 PM   #1 (permalink)
View cam1101's Photo Gallery
4th Generation 1998 Camry ABS light
I was storing my car outside, it sat for probably 4-5 months. I just started driving it and I noticed the abs light is now on. It was wet out and I tested the brakes and they "lock up" instead of acting with the antilock? Everything was fine before I stored the car. Any ideas?
On the plus side, I just got 5% tint all the way around with clear corner lights, I'll be showing pics soon...
cam1101 is offline   Reply With Quote
Old 07-23-2009, 05:21 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
It's probably frozen up a bit? Pull the wheels and inspect the brake hardware...
...and post up some piccies of them, too!
BamZipPow is online now   Reply With Quote
Old 07-23-2009, 05:31 PM   #3 (permalink)
A.K.A WALDO
wald0's Avatar
View wald0's Photo Gallery
if da abs is on it means dat the abs isnt working at all. thats y its lcoking up. maybe it needs brake fluid? or not enough pressure to the hydraulic lines.
wald0 is offline   Reply With Quote
Old 07-23-2009, 09:22 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Pull the battery terminals off for 5 minutes. Re-connect, start the car and see if the light comes back on. If it does, take it to the shop and have them test the wheel speed sensors and control module. ABS problems usually arise from wiring issues, bad control module or bad wheel speed sensor(s). Good luck.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
