LED flasher Module - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2009, 02:51 AM   #1 (permalink)
View .Camryman97.'s Photo Gallery
4th Generation LED flasher Module
hey guys i recently bought some front and rear led bulbs for my 97 camry. well i ordered the rear first and had them for a couple of weeks and had the hyper flash but when i got the front led turn signal bulbs turns out front and rear led turn signals doesnt go well with the stock flasher module and so it didnt work so i know v-leds has led flasher modules you can buy but can anyone help me out on which one i need to get???
thanks
http://www.v-leds.com/Electronic-LED...s/c122487-1-3/
not sure which one to get
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 07-25-2009, 07:38 AM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
superbrightleds.com has flasher relays and this is a link to the main page, close to the bottom, the "More info" link will take you to a list that can to help you find which one you need. You can find out which socket layout it is and match it to one on v-leds.com or just buy it from them.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 07-28-2009, 09:43 PM   #3 (permalink)
well i looked there but im still puzzled because none of them have the thing on the left in this picture
any help???
Old 07-28-2009, 11:22 PM   #4 (permalink)
pro nub
View trdcamry00's Photo Gallery
Try a tridon stant ep35
trdcamry00 is offline   Reply With Quote
Old 07-28-2009, 11:52 PM   #5 (permalink)
well when i was putting back in it looks like the cover that goes over it covers that piece on the left like it has no purpose or somethin
Old 08-04-2009, 04:12 PM   #6 (permalink)
well i got the 3 pin japanese from v-leds and it doesnt work
anyone no which one i should get to fix my hyperflash and work with led front and rear turn signals????
Old 08-04-2009, 04:14 PM   #7 (permalink)
http://www.superbrightleds.com/flashers.htm
mine matches the japanese and thats the one i ordered... so either i got a falty on or i have a german flasher module which i wouldnt think i would have unless i read the lettering wrong on mine
Old 08-04-2009, 04:20 PM   #8 (permalink)
????????????? is mine a german style
left: oem................ right: one i order from v-leds
Old 08-04-2009, 04:45 PM   #9 (permalink)
Annabelle likes to ride!
View NateTheBookie's Photo Gallery
It looks like the B & E leads are just swapped, heat-flashers usually work backwards, but semiconductors usually don't... Depending on how the flasher's assembled and potted, you may try cracking it open and swapping (de-solder/re-solder) those two leads, but it will definitely void your warranty/return policy.
'99 Camry 4 Cyl "Annabelle"
The PO is always an idiot.
NateTheBookie is offline   Reply With Quote
Old 08-04-2009, 07:29 PM   #10 (permalink)
not sure if i have the skill to do that
Old 08-04-2009, 07:30 PM   #11 (permalink)
http://www.v-leds.com/BlinkerWarning...81116-1-3.html
the european verson looks like its laid out right.... would it work???
Old 08-04-2009, 07:33 PM   #12 (permalink)
DxElite's Avatar
...that's pretty odd, I haven't tried to get an LED flasher module for my car yet so I don't have any input on what could be the problem.
But if you want to try what NateTheBookie is suggesting by swapping the B and E leads, use some wires with with male and female connectors to extend the leads so you can plug it in swapped.
...to be a bit more clear, get 3 wires with a male and a female connector on each end. Make them long enough so that you can easily plug it into the car socket and into the new relay. But swap the wires so that the B and E wires from the car socket to the relay.
...I think that makes sense, I can picture it in my mind, putting it into words looks confusing.
Old 08-04-2009, 07:36 PM   #13 (permalink)
i think i see what your saying but im talkin with v-leds to see what they will do for me... im tryin to see if they will let me ship back the japanese and try to see if the european version will work
Old 08-04-2009, 11:13 PM   #14 (permalink)
im open to more ideas or helpful info
thanks for all the help so far
Old 08-05-2009, 09:08 PM   #15 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
My Camry (also a 97) have that adapter piece too. Its purpose is to adapt a "JSO" flasher to "ISO" pinout that the car needs.
You need the CF13GL-02 flasher. I have one for my piggy and they share the same flasher type.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
