GEN4 - Things need to remove 6disc cd system? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2009, 12:10 PM   #1 (permalink)
WheresMyCar's Avatar
View WheresMyCar's Photo Gallery
4th Generation GEN4 - Things need to remove 6disc cd system?
I used a screwdriver to remove the changer
Now, how do I get the dash cd player out and the connector cable from dash to trunk?
WheresMyCar is offline   Reply With Quote
Old 07-25-2009, 07:58 PM   #2 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
Assuming you want to put in aftermarket CD player, remove the bezel around the shifter. It should pop out, then remove the ashtray/coin holder. After that, there is a tall bezel that surrounds the A/C controls and radio. Gently pry that off and there should be four 10mm bolts holding the radio in. Get them out and the radio will slide out, unplug it ad you're set. I wouldn't remove the wiring, if you ever sell the car and want to put the OE stuff back in you have to re-run the wires. Leave them and you'll be fine.
PortugalFocus is offline   Reply With Quote
