Hot AC need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2009, 10:37 PM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Hot AC need help!
I have little problem with my air conditioning unit its blowing hot air... I had my timing belt replaced and when I got the car back the windshield washer tank was disconnected the brake sensor wouldn't go off. I had to disconnect that to have my cruise control working. I'm wondering if it might need charging but when I turn the AC on the radiator fan usually comes on as well now it only comes periodically like when driving for a long time. I need help to see if anything else might cause that to happen before I think about the worse situation like the compressor.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 07-25-2009, 11:16 PM   #2 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Is the compressor switching on or no? Listen for a click when you turn the AC on. Your engine should sound considerably louder...
You could also disconnect the compressor power (bottom right of engine, near the high pressure valve). Take a paper clip. There are 4 holes. Join together the 2 that are closer together to each other with the paper clip. This should force the compressor on.(This test is to see if the compressor even turns on...)
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 07-26-2009, 02:37 PM   #3 (permalink)
View sepias's Photo Gallery
From the other problems you were having, I would agree that someone forgot to hook somthing up. But I had a similar issue and it turned out that a rock went through my AC condenser. You might check it for a hole while your under your car.
sepias is offline   Reply With Quote
Old 07-27-2009, 01:10 AM   #4 (permalink)
JayMax03's Avatar
might need a pic of that never heard of that before
