Autozone Radiator Fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2009, 11:50 PM   #1 (permalink)
View Kozg's Photo Gallery
My driver side radiator fan stopped working so I went to Autozone to get the VDO PM3777 radiator fan motor. The mounting holes line up, but the motor won't sit flush in the fan shroud due to the metal band / mounting bracket. I ground the lip down, but it didn't help much. Don't want to force it and crack the plastic shroud.
Has anyone else ran into this issue, or can you suggest a replacement motor?
Just curious, but when does each fan operate. Currently the passenger side fan kicks on when the car gets hot and when i turn on the a/c, but it's the only fan right now. Does the driver side only kick on when the a/c is on? No overheating issues, but the a/c doesn't work well at idle.
2000 Camry 2.2l
Kozg is offline   Reply With Quote
Old 07-27-2009, 12:51 AM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
This should be the correct the radiator fan AND AC fan.
http://info.rockauto.com/FourSeasons...html?35254.jpg
However, are you sure the car didn't have:
http://info.rockauto.com/FourSeasons...html?35112.jpg
Just wondering.....
2000 Camry 2.2l
Old 07-27-2009, 12:54 AM   #3 (permalink)
Both should operate when AC is ON.
Old 07-27-2009, 10:27 AM   #4 (permalink)
This link looks just like the fan motor i have. The band surrounding the motor keeps it from seating in the bracket correctly.
Old 07-28-2009, 11:17 PM   #5 (permalink)
I went back to Autozone and tried a fan for a 95 Camry - Siemens VDO PM3900 and it fits the fan shroud for my 00 Camry. My car was i a wreck before i got it. Maybe they put the wrong shroud in. I'm going to investigate further.
Old 07-29-2009, 09:31 PM   #6 (permalink)
No wonder!
