difficulty starting 98 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2009, 06:29 PM   #1 (permalink)
View twocamrys's Photo Gallery
I have difficulty starting my 98 Camry (4 cyl) in the mornings or when I haven't driven the car for a few hours. When I turn the key on the ignition, it clicks a few times and sounds like the battery is dead. If I continue to turn the ignition, it will eventually start up fine. The car drives normally and doesn't have any trouble starting unless it hasn't been driven in a few hours. Does anyone have any idea what could be causing this? I was getting ready to change out the spark plugs before this started. Could this be a sign of worn spark plugs or is there another possible cause?
twocamrys is offline   Reply With Quote
Old 07-26-2009, 06:44 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Sounds like your starter solenoid contacts are worn out. It's a cheap and easy fix, I know there is a DIY somewhere.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
