Some squeaking in the belt area? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2009, 12:10 PM   #1 (permalink)
View Shapeup1's Photo Gallery
93 camry 6 cyl.
Someone told me to sparay some wd40 on the belts and pulleys? Any truth to this?
Thanks
Shapeup1 is offline   Reply With Quote
Old 07-28-2009, 01:26 PM   #2 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Originally Posted by Shapeup1 View Post
93 camry 6 cyl.
Thanks
Did you try the most common reason for belt squeal? Check to see if the accessory belts are glazed over or damaged in any way. Next, check if the pulleys are properly torqued down properly. Hope that helps!! You might wanna try some belt dressing also...
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 07-28-2009, 01:58 PM   #3 (permalink)
Gameroom cash: $303255
"Did you try the most common reason for belt squeal?"
IMHO the most common reason for the belt(s) squeaking is a loose belt. Did you check the tension and/or try to tighten the belts.
Mike
Old 07-28-2009, 03:40 PM   #4 (permalink)
Strum's Avatar
View Strum's Photo Gallery
I would go with either response. If the belt is loose I would venture to guess that they have glazed over if the condition was going on for awhile.
Funny thing, I've never had it on any of my Camry's current or past, but I have on my Corolla's both current and past.
I've never heard of WD40 on belts (I would think that would only worsen the slipping). Dressing is more of a temporary fix or a delay in the inevitable tightening or replacing.
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 07-28-2009, 04:00 PM   #5 (permalink)
TN's Mad Chemist
By tightening the pulleys, I meant tightening the belts, sorry
1997 Acura RL-Gone
Old 07-28-2009, 04:11 PM   #6 (permalink)
thanks for the ideas.....
