Crank Sprocket is stuck! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2009, 01:46 AM   #1 (permalink)
View TheShagg's Photo Gallery
I am in the middle of a front seal job and timing set, and I can't get the crank sprocket off! This is a 98 4cyl. I've tried prying. I've tried channel locks. I've tried penetrating oil. I even tried a little bit of propane. No dice.
Unfortunately, mine doesn't have the two holes in it for a puller.
Any ideas?
My last ditch ideas are to try more propane and something cold like that "air in a can" stuff, and if that doesn't work, I will drill and tap two holes and pull it off.
Now that I've done a good job of boogering it up with the channel locks, do I need to replace it? Will I be able to find one of these anywhere? (with the threaded holes would be nice!)
Thanks.
TheShagg is offline   Reply With Quote
Old 07-29-2009, 07:17 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Wow thats weird. I just did the timing on ours this weekend after the water pump seized and the crank bolt came off no prob with an impact gun. I went to go get a harmonic balancer puller kit but the pulley just slid off after i spent 2 trips to go get one.....
If there really arent any threads, you gotta do what you gotta do to get it off. I think a new one is around 130 at autozone.
carsrus is offline   Reply With Quote
Old 07-29-2009, 11:28 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
plan B - do you have a gear puller? (but this can damage, crack, break the pulley)
i would just pick up a single tap and make your own for a puller
what area on the crank pulley did you "booger" up? if its where the belt contacts, you can probably clean that up with a file if the damage isnt too bad as to wear on the belt over time.
Old 07-29-2009, 11:36 AM   #4 (permalink)
I am talking about the sprocket that turns the timing belt, under the timing cover, not the damper/pulley.
Old 07-29-2009, 11:50 AM   #5 (permalink)
View davemac2's Photo Gallery
well, can you figure out why it is stuck? Is there rust due to a leaking water pump or something? Is the crank shaft nicked from your efforts? Is it bent somehow? That should slide off very easily since it is only keyed to the shaft and nothing more. These of course don't have any holes for pulling since it is normally not necessary.
Can you get a bearing separator underneath it? ie.: http://www.harborfreight.com/cpi/cta...temnumber=3979
dave mc
davemac2 is offline   Reply With Quote
Old 07-29-2009, 11:59 AM   #6 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
Shagg - It's been awhile since I did my timing belt, but on the 1996 4 cylinder 5SFE, there is a cupped washer (ie. belt guide) that keeps the timing belt on the pulley.
If you can pull this cupped washer off, it should expose two holes on the crank timing pulley.
I can't say with certainty, but I think that the holes are threaded. It looks like they are in the photo below.
I hope this helps...good luck mate!
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 07-29-2009, 12:47 PM   #7 (permalink)
Mine looks exactly like that, without the holes. LAME!
Any idea where I could get one of them WITH holes, once I finish destroying mine getting it off?
Old 07-29-2009, 12:48 PM   #8 (permalink)
dave mc
Crank should be fine. There might be a little rust, I think there was a water leak before I got the car, but the amount of rust is small (but it doesn't take much!)
No friggen way to get something behind the sprocket.
Old 07-29-2009, 01:05 PM   #9 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Using M42 alloy HSS drill bit with split point, drill two holes 6.75 mm diameter 20 mm deep
then use metric tap M8X1.25 [buttom type to tap both holes]
Then use 12.8 class metric screws for your puller.
you may also use 5/16 tap and bolts grade 8 or stronger.
Doctor J is offline   Reply With Quote
Old 07-29-2009, 01:20 PM   #10 (permalink)
View eric.b's Photo Gallery
Shagg,
Here's a shot in the dark idea before you try any further brute force methods. Mabye the "key" in the shaft is jammed past the "keyway" in the sprocket pulley. Try turning the sprocket pulley counterclockwise relative to the shaft and see if they line up better. Obviously the shaft is going to try to turn so put a screwdriver on one of the sprockets (tangentially to the pulley) and tap the pulley counterclockwise.
eric.b is offline   Reply With Quote
Old 07-29-2009, 02:52 PM   #11 (permalink)
Gameroom cash: $162600
View blackcloud's Photo Gallery
my pulley was stuck also
i took a small wedge put behind pulley. hit wedge VERY LIGHTLY with hammer it came off be very careful not to damage front of engine the older engine you put two screwdriver behind pulley and rags behind screwdriver pop it off
Timing gear, camry, crankshaft - 2.2l - 2.2L
97-01 $26.06 $19.12 at dealer
list discount
blackcloud is offline   Reply With Quote
