Hesitation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2009, 11:34 AM   #1 (permalink)
Gameroom cash: $160210
View FLIP K1DD's Photo Gallery
3rd Generation Hesitation
After much work has been put in, i am bout ready to drive my car off a mountain. I really need to get this car working before my son is born sometime in August. i dont wana miss his birth!
179,XXX miles. anyways i replaced coil, ignitor, fuel pump, spark plugs, wires, cap & rotors. the major idle and low rpm hesitation has gone away but two days later it came back only during high rpms. mainly 40-45+mph. its not very noticeable, but if your behind the driver seat it gets really annoying. im afraid this will worsen
the spark plugs, wires, cap & rotors are the oldest out of all that ive replaced, but are still new
any ideas? plz help
some describing words for this: boggs, hesitation, gasping, coughing, old lady about to die from smoking, hiccup
FLIP K1DD is offline   Reply With Quote
Old 07-30-2009, 01:00 PM   #2 (permalink)
Gameroom cash: $303255
"the spark plugs, wires, cap & rotors are the oldest out of all that ive replaced, but are still new"
Exactly how old are they? I have seen aftermarket wires fail in as little as 1 year or 20,000 miles.
Mike
Old 07-30-2009, 02:59 PM   #3 (permalink)
i purchased wires, plugs, cap & rotor on 4/29/09. the plugs are autolite dbl platinum :\ maybe i should go bosch or ngk? wires are called "OEM Standard"..thinking about returning and getting the actual one from the dealership.
when we fixed the major idling roughness problem, we also noticed that we installed the cap in upside down..so the sparks were going off at the incorrect time. we fixed that and the car ran better and felt like new for 2 days.
maybe that killed the spark plugs or something idk?
Old 07-31-2009, 07:05 AM   #4 (permalink)
"maybe i should go bosch or ngk?"
Stick with the proper NGK or Denso plugs as per your owner's manual. Some people on this forum have reported problems using Bosch plugs. On plug wires, I prefer to stick with Toyota OEM.
Also, have you checked for engine trouble codes and have you cleaned the throttel body?
Mike
Old 07-31-2009, 06:26 PM   #5 (permalink)
View cj0609's Photo Gallery
I had similar problem at low rpm after doing the same work. I couldnt figure out what it was for a week. Finally changed the plugs again and it fixed the problem. I must of cracked or bent one while putting on the new wires. Maybe your wires went bad. Good luck with the car and the baby.
cj0609 is offline   Reply With Quote
