Woohoo. Installed Tweeters! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2009, 05:16 PM   #1 (permalink)
View caveman017's Photo Gallery
4th Generation Woohoo. Installed Tweeters!
Went Junk Yard shopping today. Not much at all there for Toyotas. Only 2 Gen 4's, both gutted pretty bad. Found a 95' ES300 though that looked in good shape, so I took the tweeters out.
Took 2 hours to install the first... 30 minutes for the second. I placed them where they "should" be and drilled a bunch of tiny holes in the plastic there. Best part---it worked!
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 07-30-2009, 06:44 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
nice work man.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-30-2009, 07:17 PM   #3 (permalink)
Noticed a slight problem. The tweeters are too loud. I spliced in with the regular 6.5 front speakers, and although when at lower volumes it fine, the tweeters really get to loud at a "regular" volume.
What size resister (I assume resister, right) would I need?
Old 07-31-2009, 06:51 PM   #4 (permalink)
Anyone have an idea about the resistor?
Old 08-03-2009, 02:28 PM   #5 (permalink)
Bump
Old 08-03-2009, 06:52 PM   #6 (permalink)
View skuttduck's Photo Gallery
My 2000 Camry LE had tweeters in it. They were just wired in parallel with the 6.5's in the door.
I still have the factory tweeter here with me, and it has a capacitor on it. In case you wanted to know the part number of the left tweeter it is 86160-AA200
skuttduck is offline   Reply With Quote
Old 08-04-2009, 09:24 AM   #7 (permalink)
View Fruitbat's Photo Gallery
tweeters need a crossover to work properly - they're only supposed to get high-frequency sounds. Pumping a full range signal through them will make them sound like crap, and blow them out very quickly.
You need to get a cross-over going - a passive x-over can be as easy as a capacitor on one of the wires going to the tweeter. If you can go back to the car you ripped the tweeters out of, you should be able to find the stock cross-over somewhere on the wiring in the door IIRC.
Old and Busted: '84 Camry LE <2S-E> || '89 Celica GT-S <3S-GE> || '91 Camry LE <3S-FE> || '95 Camry LE V6 <1MZ-FE>
New Hotness: '08 Matrix XR <1ZZ-FE>
Fruitbat is offline   Reply With Quote
Old 08-04-2009, 10:18 AM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
If you took the door speakers in the donor car, you would be all set.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
