If I wire my Pioneer AVH-P4100DVD's 12v power directly to my battery... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2009, 04:12 AM   #1 (permalink)
Kyle_Mains's Avatar
View Kyle_Mains's Photo Gallery
will it stop turning off when I turn the car on?
I hate when that happens, messes up the menu function on my iPod adaptor.
SQ > SPL
Throwing 1,000 watts of rattle in your trunk does not mean you have a "system".
Kyle_Mains is offline   Reply With Quote
Old 07-31-2009, 01:32 PM   #2 (permalink)
View Manny1337's Photo Gallery
i believe it will drain the battery and run all the time. unless you have a cutoff switch somewhere inbetween the line.
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 07-31-2009, 02:02 PM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
^ the headunit would have the on/off button by itself ...
Zviator is offline   Reply With Quote
Old 07-31-2009, 02:10 PM   #4 (permalink)
didnt think of that haha. but yeah it would be on all the time unless you shut the headunit off itself
Old 07-31-2009, 07:16 PM   #5 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
I tried it already and my deck still cuts out when I take the key out. I know watching those DVDs with the key out is tempting but it didn't work for me .
Also, I did connect my deck straight to the battery and it was really really unsafe. If you have to, install a relay then to the battery at least.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 07-31-2009, 11:53 PM   #6 (permalink)
Kyle_Mains's Avatar
So, other than adding a new battery, there is no way to make your stereo stay on when you turn over your engine?
SQ > SPL
Old 07-31-2009, 11:57 PM   #7 (permalink)
View frojoe's Photo Gallery
It will still cut out. Head units are designed to turn off when the voltage drops below a certain point, and when you start the car this happens even when hooked up direct. You would need a second battery I'm pretty sure. Won't hurt though, as long as you give it a switch.
Edit:I was typing as you put up your last post, but you are absolutely correct, a new battery is the only way.
frojoe is offline   Reply With Quote
